Flexi Printing 1/6th of Design ?
NikGrey
Re: Flexi Printing 1/6th of Design ?
Post by NikGrey »
So, I have had to use Flexi to print my Black T-Shirt design onto xxxx paper (I will post paper supplier once we settle my small problem - as unhappy at the moment).
The reason for this is outlined in another of my posts (Which, I had taken off topic).
I have my design in Flexi, it was designed in Photoshop and I deleted the background before saving (Allowing you to cut a Contour Cut in flexi by opening the .PSD file, Groping an Ungrouping everything and applying the 'Contour') BUT now when I try to print from FlexiStarter I get this - and only this:
[ATTACH=CONFIG]2009[/ATTACH]
This is the Original:
[ATTACH=CONFIG]2010[/ATTACH]
It's driving me crazy !
vB_ID:2010
vB_ID:2010
vB_ID:2009
vB_ID:2009
gorgall2
Post by gorgall2 »
Is your paper size set correctly?
GoldRapt
Has thanked: 5 times
Been thanked: 7 times
Post by GoldRapt »
Is this RIP and Print? Is your Printer capable of using the Flexi RIP or are you printing using the print screen then cutting?
regards
Tony
-launching july/august 2026
NikGrey
Post by NikGrey »
I have Flexistarter which doesn't support RIP & Print, I am just hitting the Print icon.
So I am printing the screen and then cutting.
The 'Paper Size' is a good question as this is another thing this mouse does, keeps changing the material size without me noticing. I have to keep going back and re-checking settings before doing anything serious.
There are some Print Options here 'Substrate' etc and I cant find an explanation for them.
[ATTACH=CONFIG]2012[/ATTACH]
...Also something odd is going on - it's taking over 5 mins for each print to get sent to the printer - and I notice this is taking over 10GB from available space on the HD (I gave myself 50gb thinking that was more than enough - i am resizing my disks, I am hoping this was my problem with printing as i was getting down to .kb's remaining which is obviously undesirable).
vB_ID:2012
vB_ID:2012
vB_ID:2011
vB_ID:2011
