any one doing Edible printing
Limara
Re: any one doing Edible printing
Post by Limara »
Do you use templates or have a easy way to do multiple different images on one sheet? I am playing with edible artist and I am sure there should be an option in that but i cant see how! I can select which individual circle i want to edit but then cant get back to that page to select another circle! and if I save and then reopen and select a different one then save again it only saves the new.
I have been considering buying a edible ink printer for a while now and its time to buy, cant justify spending out any more money if I cant do what I need to do, also any one using a cutter with it how successful is it? I have seen the cameo has been modified for edible printing
Limara
Post by Limara »
answering my own question, about the software incase any one else ever looks for it for some unkown reason the software requires you to press the nackgrounds button then go back from there even if you havent added a background!
