I have dealt with 4 colour production for 13 years, I use a 27" iMac photoshop/indesign etc, calibrated screen using my normal printer, a Xerox 7500 and have never had any issues with colour profiles. What I see on my screen is what I get from the printer.
However, I have been trying to set up my new Ricoh 3110, have downloaded, from what I can see, all the relevant drivers and profiles and followed the set up settings. When I print, the image is dull in comparison to my screen and the colours are not vibrant at all.....can anyone tell me where I might be going wrong?
Ellie
problems with what I see and what I get......
- elliemillhill
Re: problems with what I see and what I get......
Using a 27" iMac, 21" imac, Xerox 7500 printer, Richo 3110, Black Cat Cougar 24", 15"x15" Nix Heat Press, Mug Oven, A3 Guillotine, Wire Bider, Stitcher/Folder, Bench Stitcher, Adobe CS6 + others.....
press it on something and colours will appear. aper is only to transfer image to substrate. is not final.
- elliemillhill
Hi Paul, I did wonder about that, it's just I'm so used to looking at WISIWYG......thanks
sublimation ink is heat sensitive. so real colours ill show up after heat is applied
- elliemillhill
First attempt on first mug, hot off the press.......Paul;76896 wrote:sublimation ink is heat sensitive. so real colours ill show up after heat is applied
- vB_ID:1944
- IMAG0439.jpg (93.2 KiB) Viewed 22 times
nothing wrong with the colours
- elliemillhill
yep........thanks again
