2 questions
does anybody know who sells stringer vest for body builders wholesale needed asap
also when I press tshirt s it leaves a line from the paper on the tshirt have tried most things
getting me down all advice much appreciated x
Advice needed please
- mrs maggot
Re: Advice needed please
stringer vests has been well covered on here before, if you do a search,
the paper issue has also been discussed, you need to tear around the paper so there is no straight line, you may also have your press a little tight.
A lot of things will have already been covered on here, so sometimes its worth putting your key words into the search up at the top
