looking for a pint glass for t-shirt design
Dave271069
Re: looking for a pint glass for t-shirt design
Hi ive been asked to do a stag weekend t-shirt, they want the usual stuff but in the middle of the writing they want a pint glass, does anyone have something i can use in any format, so i can send it to my cameo to be cut out in vinyl, was going to go down the route of a transfer but on black t shirts they usually don't look good.
Dave
Dave
Hi Dave
I have these as clipart. I will upload an EPS file to the downloads section of the forum. Not sure if any of them are suitable for you or not.
[ATTACH=CONFIG]1925[/ATTACH]
- vB_ID:1925
- X3003383.jpg (51.93 KiB) Viewed 366 times
Dave271069
ive found one at the moment simon, but i want to show the customer, only problem i have is ive designed the tshirt in silhouette software and i cant save it as a jpeg etc, so might have to do it again in something else, unless someone knows.
Dave271069
I do not know that software, but can you zoom in on the image, do a screen grab and then paste in to Photoshop and clean up?
Dave271069
- harlequeen
Can you save the image as png then you can open it in other graphics package and save as jpg
- purpledragon
google pint glass loadsa images out there or google pint of guiness photoshop the logo out and hey presto almost a sillouette of a pint glass
tlworkwear
Hi Dave,Dave271069;76256 wrote:ive found one at the moment simon, but i want to show the customer, only problem i have is ive designed the tshirt in silhouette software and i cant save it as a jpeg etc, so might have to do it again in something else, unless someone knows.
What I did when I was using the Silhouette software and needed to create a PNG or JPG to show a customer was use Bullzip , its a free PDF printer and all you then do is go to file/print like you would normally but then a window comes up with the option to save as PDF, PNG, JPG or some other format. You might have to play about with it a little to get the correct settings but well worth it as that was the major drawback of the Silhouette software IMO. Hope this helps
Dave271069
Cheers all for your replies.
In the end I did a screen shot and opened in another program then photoshop. Cut out everything apart the image and saved as jpeg. Customer was happy with design.
Silhouette is a cracking machine and software but could do with some minor tweeks .
