Automatic Mug Taping Machine
Andrew
Re: Automatic Mug Taping Machine
Post by Andrew »
Did I see a thread on here for an automated machine for taping transfers on mugs? I remember seeing it somewhere but failing in my current searches. It's not the automatic tape dispenser but the actual paper transfer to mug automation set-up.
No, I never started this thread...oh ok then yes I did ;-)
http://www.dyesubforum.co.uk/vbforum/sh ... matic+tape
Andrew
Post by Andrew »
Thanks Justin but not that thread. Might not have seen it on here but the machine actually had the paper loaded and placed that around the mug as well. Blank mug goes in and ready to print one comes out.
Oooh, never seen that I'm afraid but sounds interesting! ;-)
Do share if you ever find it :smile:
mrs maggot
Post by mrs maggot »
blimey, i would need a bigger unit - not to mention more customers Pisquee
Would be amazing if everything could be automated and just happen while I watch TV!
Sometimes I love that you can automate processes in Photoshop, and just set it away to do a batch of images in one go, but even then, there's somethings that you can't automate enough, and then you have to set it up in the first place...!
Andrew
Post by Andrew »
That was the one I was looking at..... although I thought it was smaller. Would like a compact version to iust pop a mug in and it comes out the otherside taped.
Why not build a heat press into the machine too, and an inkjet printer?
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
