any one know any good (read cheap) supplier who sells silver, silver mirror or reflective flex and wont charge the eatrh for p&p?? I need only few sheets or 1m will do.
thanks
flex needed!
- Has thanked: 11 times
- Been thanked: 9 times
Re: flex needed!
Have you ever used Xpres XP3008 Easy Cut? The glitter/metallic ones are brilliant. Not the best for very fine detail as the backing isn't tacky but still weeds really easily.
The material comes in 34 x 49cm sheets, think you can just buy 1 sheet of each. You can even get pantone matched material if you need it (min. 20 sheets for that though)
Well worth a try.
Well worth a try.
Re: flex needed!
Just looking on the Xpres website, I hadn't realised they had released more vinyl materials, there's some really interesting stuff on there.
Re: flex needed!
all I need is writing. web site address on back. do you think would it weed well?
Re: flex needed!
Piece of cake, I used to do fairly detailed work, it's just when you get down to really tiny stuff it's tricky.
Angie-Stitch-Up
Re: flex needed!
You might want to try BMS. You can buy a handful of sheets (say 5) suited to the CraftROBO and pay only £2.15 for First Class postage. Pick your own sheets - they don't need to be all the same colour.
