Silicone rubber pad for 15 x 20 press
DS Designs
Re: Silicone rubber pad for 15 x 20 press
Post by DS Designs »
Hi all, anyone know of a UK supplier for a replacement silicone pad (the bottom rubber pad on the heat press table) that will fit a 15 x 20 press?
Yes, i've tried the manufacturer who want over £60 plus VAT and delivery
Cheers
I bought one from Coralgraph, had same quote as you from the manufacturer. CG's is a little larger but works perfectly ok.
DS Designs
Thanks Justin, I'll drop them a mail..cheers...
Sent from the sarlacc pit using Forum Runner
