Printer lines
Burrelly7
Re: Printer lines
Post by Burrelly7 »
Having a few problems with my Epson WorkForce Pro WP-4015 DN.
ive started getting lines across my images. Any ideas people? Thanks GaryGary
vB_ID:1851
vB_ID:1851
Sawgrass
Re: Printer lines
Post by Sawgrass »
Burrelly7;73918 wrote:Having a few problems with my Epson WorkForce Pro WP-4015 DN.
Looks like missing nozzles to me - have you run a nozzle check?
Burrelly7
Re: Printer lines
Post by Burrelly7 »
Yes, done 3 or 4 and its no better! :-(
Re: Printer lines
There are few sublimation suppliers selling these so 'experience in the field' by members here will be limited apart from the usual 'nozzle check', 'clean heads' etc. Best to contact your supplier for technical support on this but in the meantime double check all your settings against the Sawgrass instructions.
Re: Printer lines
This problem looks a lot like the one I've had on my Ricoh. Can you check head alignment etc on this printer?
Sawgrass
Re: Printer lines
Post by Sawgrass »
Suggest that you call Steve at our Tech Support on Monday, as he specialises in Epson and may be able to help you
Burrelly7
Re: Printer lines
Post by Burrelly7 »
Thanks for the replies guys. Ill give Steve a call this week
