OSX Parallels - CorelDraw Install Issue
Any OS, software in here.
Re: OSX Parallels - CorelDraw Install Issue
I've installed Parallels on my iMac along with some PC software, no problems.
When I try to install my CorelDraw X4 I quickly get an error "Could not access file......../setup.msi" The System cannot find the path specified.
I've tried running the install directly from setup.exe but it won't allow it. I'm pretty sure it's something to do with the DVD path as Parallels loads the DVD as a virtual drive and is therefore given a drive letter other than the usual D.
Anyone any ideas how I might get around this please? I've tried copying the CD contents onto the iMac but same issue appears. I've managed to install a trial version which runs perfectly but for some reason won't take my registration key.
copy all files in to the folder and try again. had similar issues with other software. changing location should fix this problem.
Looks like it's worked this time, I must have copied into the wrong directory or something, anyhow all working :-)
