Sublimation quality from laser printer
Signguy
Re: Sublimation quality from laser printer
Post by Signguy »
How does the quality compare printing on to mugs using inkjet sub as compared to print fom laser printer.
I have an epson aculaser c4000.
Trying to justify an exclusive printer for sublimation looking at the epson wf a4 with a bulk ink cartridge system then top up with the sublijet iq so the profile will work.
If the quality is not too far away may build demand with the laser printer.
logobear
Post by logobear »
sub mugs are better in every way, texture, colour and finish are better, and the 'process' is much easier and produces less waste.
I did laser mugs for years, i realised i was a mug when I saw how easy and good sub mugs were. I rejected them for years because it meant getting new kit, but I was wrong, laser mugs are poor and a hassle, but mugs are aasy and great.
imho
Even if you asked this same question to TMT you would get the same reply - sublimation prints are of a better finish and quality :)
A bit of apples and oranges here.
Sub is far better for the finish but laser can do more.
Sub in general can only be used on white and blank stock is only available in white. If you have the TMT white system then you can print on different colours (including mugs).
Ask_Alan
Post by Ask_Alan »
Different things, Sublimation "Dyes" the polyester coating, result is shiny and almost indestructable in normal use. With the correct coating is dishwasher proof. Slightly soft image. Requires a white mug.
Laserprint, Sits on the surface of the mug (Bonds to the coating), needs glazing ie heating in an oven or on a lamp type press to gloss and harden. Can survive diswashing but will scratch. Sharper image than Sublimation, will work on uncoated mugs though not usually dishwasher proof. With the white toner can work on coloured mugs
Other methods
Waterslide transfers, can be ok if baked on. generally for decorative purposes only. Coated mugs not needed.
Ceramic prints (done with modified lasers). Uses enamel toners and requires a kiln to apply, Kit is expensive, result is indestructable apart from a hammer. Coated mugs not needed. Usually the transfers are bought in from specialists
There are other ways Screen printing and pad printing come to mind but these are long run processes.
alan
Signguy
Post by Signguy »
Thanks think we will bight the bullet and get the sub system already got an adkins press for mugs.
Cheers
