rhinestones
Re: rhinestones
hi
quick question a friends asked for some tshirts with rhinestones on for a party, never done this before so some basic questions:
can I use cotton tshirts that she already has or do they have to be specifically made for rhinestones?
what tape do I need to use - going to make my own design and want to know what tape I need to stick the rhinestones to (I understand my design needs to be printed our in mirror view)and from a short video on YouTube I note that they stick some sort of clear tape to one side of the stones and the back that was peeled of to the otherside, not sure which way the stones need to be put on my design and what this tape is about so that they are the correct way so when I heat press them they stick to the tshirts the correct way. Is there a tutorial or can anyone advise?
and if I wanted to do a design with dye sub ink and add a few rhinestones can that be done on a heat press if so what do I do first or how would I apply the stones to the image or cant it be done as I would have thought if you do the image 1st then reheat for the rhinestones you would ruin your original sub image?
finally is there a specific sort of rhinestone I need to get with glue on the back?
thanks Lisa
thanks Lisa
TransferGraeme
Re: rhinestones
Hi Lisa
We can offer everything you need [url="http://www.thetransferpress.co.uk/acata ... rview.html]http://www.thetransferpress.co.uk/acata ... rview.html[/url]
If you need anything more don't hesitate to PM me or phone.
Re: rhinestones
Thanks Graeme
Only thing im still not sure of is around if you want to add some rhinestones to a sub image or flock wording, can you do the image/wording 1st with the heat press then go back & add the rhinestones and reheat or is that too much heat for the original image if you see what I mean?
original element of the question pasted below:
Thanks Lisa
Thanks Lisa
TransferGraeme
Re: rhinestones
Hi Lisa
Yes you can dye-sub an image and then add rhinestones in a separate pressing - the temp used for the stones is much lower and does not affect the dye-sub image at all!
Re: rhinestones
A forum that may be able to help
[url="http://tbiz101forum.com/index.php?board=17.0]http://tbiz101forum.com/index.php?board=17.0[/url]
I just bought 1000 hot fix fhinestones from ebay for Australian $11,95 including postage with freemail
So I'm goin to give it a try... A new toy.... Great.
Regards
Roy N.
Regards
Roy N.
Re: rhinestones
I'm looking at making them myself.
I have a plotter cutter and should have no problems. When I get it going I'll let the board know what I've used and if someone wants a template created could do it and mail it for the cost of the mail and material.
I'm still learning but I am pretty resourceful. I think I'll have to invest in some more software.
Regards
Roy N.
Regards
Roy N.
