printing sublimation lighters help
twojs
Re: printing sublimation lighters help
Post by twojs »
Hi
I have got some sublimation lighters but when i print on them the colour does not take. The supplier says 190 degrees for 180sec. The lighters are silver. Please any help will be appreciated.
Julie
I printed my lighter 180C for 60sec. light pressure. looks good but on mirrored silver you can not see much. well. you wont as there is no white background :)
twojs
Post by twojs »
Thanks will try 60sec
Printcess Jen
Post by Printcess Jen »
Hi, just out of interest how are you printing these? ie are they flat and you are just using a press or another attachment? I would be interested to know
I did a few hundred of these a while back. They were the white ones from BMS. I used 190 degrees for 120 seconds with a medium to heavy pressure and they printed lovely.
Done in a cheap clam shell heat press. Make sure you use an old heat blanket for the bed as the lighters make an impression on the bed which will not come out.
