Pin Badge Machine - Advice Required
John G
Re: Pin Badge Machine - Advice Required
Post by John G »
I know that Enterprise use their local prison
and I did time
Had to read that a few times until it dawned on me :redface:
Yes the mini is much faster but that's still going some, 1 every 20 seconds. Especially as you'd need to stick the pins in too, which adds to the time.
Aha, I always used the "safety" backs. These are round discs with pre inserted pins.
Purchased 1000 D ring types once and threw them away as there was no way I was going to sit there and separate them out :biggrin:
Thanks for the PM John, just waiting to see what the customer thinks :-)
ASO Embroidery
Post by ASO Embroidery »
socialgiraffe;69153 wrote:Whats does a keyring machine do Sammy?
Hi
If you would like to look at keyringfab.co.uk you can view all the components was doing the sub keyrings but as you probably know there a bit fiddly where with this system there printed out as per usual on glossy photo paper punched out with the cutter and then pressed and they do a fantastic range well I like it anyway and there selling well. Probably not the cheapest on the market the punch cutters are expensive but suppose you get what you pay for.
Regards,
Sammy.
