Found a 1.2.2 firmware update and have updated it to that.
Just printed out something and works fine.
Ive only ever had it freeze up once though, so not sure if it does cure that problem.
If it happened a lot i would be in touch with the company i brought it from.
Ricoh SG3110DN 'Energy Saver Mode' 9Sleep Mode preblem.
spongerobinson
Re: Ricoh SG3110DN 'Energy Saver Mode' 9Sleep Mode preblem.
Thanks for that. I plan to get a loan of a Windows laptop sometime in the next week hopefully, and do the update then.
Has happened me a couple of times, but not every time it goes into low power. Once i've updated the firmware, if it doesn't solve the problem I will certainly get in touch with the company I bought from.
spongerobinson
just to confirm, I've finally managed to install the firmware update on my Ricoh, and it seems to have solved this issue! Hopefully might be a help to others!
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
