desperate sheild
jennywren
Re: desperate sheild
Post by jennywren »
can any one help, a customer is desperate for a wall sheild, I hope to upload a picture of this if not can you please look in the gallery. the sheild is 5.7 inches high and at its widest point it is 4.7 inches I need a template with a guide and how do I put a picture on it so it looks ok,.it looks like mdf with a white coaster effect on the front for printing. I got it of subli supplies ages ago, How long and temp please. I'll have to put it in the gallery so you can look, I'll be on msn most of the night it that helps [email:31yue40a]abigails.china@live.co.uk[/email:31yue40a]
It sounds to me like it has the same surface as the Photoluxe products. I used to print the small rectangular plaques which should be the same.
Looking on Xpres poster guide it says 200c for 50 secs (please check the poster in Gallery pics)
I use to tape the image around the plaque to stop it moving and ghosting.
Justin :-)
jennywren
Post by jennywren »
Thanks, now I need a template,please anybody. I use scotch-weld to hold the things that are to diffucult.thank you again, its quite handy for little and diffucult
http://www.coastalbusiness.com/index.asp?PageAction=Custom&ID=95
Take a look here, I reckon your shield may be on the list.
GoldRapt
Has thanked: 6 times
Been thanked: 8 times
Post by GoldRapt »
Good Post Justin,
Anyone know if there is a Heat Transfer blanks supplier in the UK as I also have a pigment ink setup in mothballs in the attic :D
regards
Tony
-launching july/august 2026
Are your inks installed Goldrapt? Only reason I ask is sublimation inks ned to be exercised regularly to avoide blockages. What system is it?
I will post links to UK suppliers.
JNMann wrote:http://www.coastalbusiness.com/index.asp?PageAction=Custom&ID=95
fantastic post Justin! any chance to stick that one:? so everybody know where to look if templates needed! Image
Got a few links to template sites, will dig them out and sticky.
Justin :-)
GoldRapt
Post by GoldRapt »
Hi Justin, I have not bought the subli(R) inks yet, must do so this week end.
My other system is a Pigment ink CISS.
regards
Tony
jennywren
Post by jennywren »
The template for the size I wanted was not on there, any ideas, also it was in a pdf. I have no idea how get any of those template in to photo shop to use as a template. Any ideas
