Ricoh SG3110DN INK VANISHING?
Renniwano
Re: Ricoh SG3110DN INK VANISHING?
Post by Renniwano »
I leave mine on all the time.. even when not used
It does all the maintainance.. and mine doesn't lose that much ink :/
logobear;68655 wrote:from memory, the initial installed cartridges are only small starter cartrridges and you don't get as much use from them as you do with proper replacement carts, something to do with priming the heads or something .....
That's not the case with the SubliJetR carts as they are all the same capacity.
derek
Post by derek »
bms;68661 wrote:That's not the case with the SubliJetR carts as they are all the same capacity.
So have you any ideas what could be the cause?
derek;68671 wrote:So have you any ideas what could be the cause?
Don't know what your printer's been doing so I can't comment precisely. I'd update the firmware first:
http://support.ricoh.com/bb/html/dr_ut_ ... 10dnen.htm
(penultimate link on page)
derek
Post by derek »
bms;68674 wrote:Don't know what your printer's been doing so I can't comment precisely. I'd update the firmware first:
Ok I will do thank you for your help
viccar
Post by viccar »
are you looking at the display on the front of the printer, or checking the actual percentage?
Because the display is not accurate.
logobear
Post by logobear »
the lcd display is only a guide to ink capacity.
If yiou can find the engineer sub menues there is all sorts of extra data about your machine that could be useful.
When I get a new printer I weigh a full cart and an empty one, to give me a true idea of exactly how much ink I am getting from each, more of a geek thing than actually useful, .... but of you can find the sub sub menu settings, you might find that the ramaining capacity is not what the crude bar chart indicates!
Mine hit empty eventually, then seem to run for ages and ages before actually needing changing!
JackB
Post by JackB »
This is how to check the correct ink levels: http://www.youtube.com/watch?v=XrEl1kMkUBA
Jack
easiprint
Post by easiprint »
JackB;68704 wrote:This is how to check the correct ink levels: http://www.youtube.com/watch?v=XrEl1kMkUBA
Jack
Goes on a bit don't he :wink:
Users browsing this forum: Google [Bot] and 7 guests
