transferring small text?
soulclaimed
Re: transferring small text?
can anyone tell me ther laser offset and blade offset for their liyu cutter?
NZACO
Are you using t shirt vinyl (cotton flex etc) if you are, why are you using transfer tape.?
If your using normal t vinyl, then you reverse the design, cut it, weed it, leaving it on the carrier sheet then turn it over and press
soulclaimed;68415 wrote:
With jet pro soft stretch on whites the white area blends well with the background so its not much issue on whites but on blacks it looks bad to have a rectangle around the text that doesnt blend well with the garment.
Ahh, think they are using inkjet transfer and want to cut around the text
Why dont you use t shirt vinyl?
soulclaimed
