Silhouette cameo
Discuss other print methods.
Lornem
Re: Silhouette cameo
Post by Lornem »
Will the cameo cut subliflock once it's been printed, does anyone know please ?
If so does anyone have one they don't use for sale before I set out to buy a new one ?
Thanks in advance
Lorne
Lornem;67715 wrote:Will the cameo cut subliflock once it's been printed, does anyone know please ?
Thanks in advance
Lorne
Yes it can, but personally I would cut it from reverse BEFORE printing
Lornem
Post by Lornem »
Thanks for that
spottraining
Post by spottraining »
bms;67732 wrote:Yes it can, but personally I would cut it from reverse BEFORE printing
Why?
I am cutting right now also my subliflock before printing. But I want to try with some logos printing and cutting method also. Maybe You can share some good tips? :)
spottraining;68294 wrote:Why?
Cutting first means you get the shape and pressing sublimation ink into it is easy then.
Printing first means you print to your sublimation printer, press the image onto the subliflock and then assume the registration marks are perfect, can be detected okay and you have to ensure the registration marks now work once the image is now the opposite way around.
Cutting first just seems much easier, but if you want to do it the harder way then it's possible, but more prone to error.
Lornem
Post by Lornem »
thanks for that ... was wondering what you meant lol
