open cart templates
Area to discuss all forms of website,design, commerce etc.
Dave271069
Re: open cart templates
Post by Dave271069 »
if i upgraded to a new template would i loose all my website or does it just convert over to the new one.? im not good with opencart so will have to get someone to do it for me anyway but just inquiring.
It should convert over the existing template as it runs alongside and you can switch between the two. I say 'should' as I've had a few slight issues with my OC site over the last few days, not related to a new template but enough to make sure I have a full back up before doing anything!
Dave271069
Thanks Justin, I would be interested to have a peek at your opencart site if you wanted to share with me via email /pm but i understand if not.
No problem, I'll PM url over to you....it isn't finished yet but you can take a peek :-)
AdamB
Post by AdamB »
Justin;67706 wrote:No problem, I'll PM url over to you....it isn't finished yet but you can take a peek :-)
but it is looking very nice at the moment ;)
Mattie
Post by Mattie »
the only problem you may have with changing a template is some extensions you may have bought will need altering to work with your new template and some extensions are only coded to work with opencart default theme.
Matthew
Good point and something that I should have mentioned. I think this is what happened with mine so I started again with latest version and only installed mods designed to work with that same version.
Mattie
Post by Mattie »
most of the time it can be fixed by going through your extension files and changing the theme name from default to your installed theme (even easier if you've got VQmod)
Matthew
Dave271069
any good links to templates?
Algozone seem very good.
