How is this printed/made?
Discuss other print methods.
Earl Smith
Re: How is this printed/made?
Post by Earl Smith »
If you look at the bill/peak of the cap you will see some text. ( Roughing it Smoothly) . This is made from a rubber like material about 1mm thick. It could be made with a mould or it could be cut using a thick vinyl and a Tangental cutter.
However its made , its very effective.
Anyone any idea how its done?
vB_ID:1603
vB_ID:1603
RogerC
Post by RogerC »
It looks like a vinyl type material that expands once heated. Just press it normally and watch it 'rise'.
logobear
Post by logobear »
the first time i saw this i thought it was some type of extruded plastic, but now is suspect it is an expanding thermal vinyl
