PM Problems
Re: PM Problems
Message did have smilies, no links. Removed smilies, still same problem. Did go over a few lines though rather than very short message.
Re: PM Problems
I can get a pm sent to you Justin just not to John G. I have cancelled the mail I sent to you from my outbox but it did go through the correct process. I have tried removing his name then retyping etc but always goes to server error.
Not the end of the world so no need to worry, just keeping you updated.
Re: PM Problems
Justin - I have found out the problem which you can see on a thread in the general section. Not sure if it is the same for Martin but it came down to the pound sign. Try posting with actually using the pound sign and see if it works as that what was stopping me. Very strange.
Re: PM Problems
Andrew
I've got the same problem here, just tried to send you a test message with the pound sign on, and got the HTTP 500 error message
Re: PM Problems
Uhm.....Andrew wrote:Justin - I have found out the problem which you can see on a thread in the general section. Not sure if it is the same for Martin but it came down to the pound sign. Try posting with actually using the pound sign and see if it works as that what was stopping me. Very strange.
Re: PM Problems
Perhaps there's a message here - the pound sign is going to be discontinued and replaced with the Eurotest message with the pound sign on, and got the HTTP 500 error message
Re: PM Problems
Hi just tried answering a post using the pound sign all that happens my end is the site freezes onto a blank page, changed the sign to the word it's no problem.
Reg
Reg
