PM Problems
Re: PM Problems
Anyone else having problems? Tried several times to reply to a member (JohnG - I haven't forgot about you
) but it keeps crashing. Used 2 different pc's and connections so guess it is not my side.
Re: PM Problems
Thanks Justin. Strange as it still doesn't work for me although it did work for me this morning.
Re: PM Problems
I'm having the same problems trying to reply to Paul. Type in the message and press submit then get an error 500 Internal Server Error...
Re: PM Problems
OK, looking into it now. Can you both check your inbox/outbox etc, just see if there's anything a-mis there, full box etc.
Re: PM Problems
All of my inbox/outbox seems as normal and I also deleted some ofthe older stuff earlier when the problem first occured. Definately says a http server error as Martin mentioned. Way above my station for me to be of any help.
Re: PM Problems
All okay from my side. Have just replied, sucessfully to your pm Justin. Still had probs replying to Paul yet a simple reply got through - no rhyme or reason. Will see if this continues and let you know (if i get some more pm's...)
Re: PM Problems
When you reply, is it a simple text reply or are you using links etc? Are the messages short or very long?
Are you using smilies?
