Hi
Just getting all my equipment delivered this week and I wondered how you set up your photoshop page to get 3 mug wraps to a page when printed? Also would I need to print all 3 at the same time or could I feed an A4 page through cut it and then do that each time I want to print a mug therefore reducing the size of the paper put through the printer to eventually get 3 mugs printed from a A4 page?
Also what size do I set the page up for printing on mouse mats and money boxes? Do I just set the paper to that size or is there a way to get more out of an A4 page based on the money boxes for instance?
Thanks in advance Lisa
templates for mugs, mouse mats,money boxes
Re: templates for mugs, mouse mats,money boxes
Hi lissa! on A4 you can not have full wrap for 3 mugs. well... you can. but not for FULL wrap. it will be to short about 1inch.
you can download some templates from [url="http://www.dyesubforum.co.uk/forum/view ... f=17&t=175]viewtopic.php?f=17&t=175[/url]
also if you want to set paper for moneyu boxes and mugs. it will be 22cmx9cm. it all depence what mugs yosu useing.
As A4 paper is 21cm wide then you can't get 3 up in Portrait - you can get 2 up in Landscape if you want to go to 22cm wide.
All depends on the image, but you can get 3 up on A4 in Portrait if you reduce the total size of the image to, say 20cm (or 20.5cm) wide by the height of the mug (95mm for 11oz, 93mm for European Mugs) - check your own mugs for total height if you want to do full top to bottom printing.
Thanks for the link Paul and the advice from you both.
Lisa
Lisa
