to be honest i dont know is the short answer , these blankets came with a 4 pin plug but a bit differnt than your standard 4 pin plug also as any supplier will probably tell you there seems to be no standard in the wireing of these blankets so even if i found a supplier using the same plugs theres no gaurantee the blanket would work on my machineRogerC;66714 wrote:Is there another supplier that you can get better quality blankets from?
am i being ureasonable
- purpledragon
Re: am i being ureasonable
Unreasonable.. No..
I wouldn't expect to be told to have to shrink my image for anything.. if it's not doing the job it was purchased for I would be sending it back..
That's like purchasing a car and being told to push it !!
might be a long shot but how about the manufacturer of the press? Assuming they are still around I would think they would help out......and be interested in the 'crap' outfit you bought it off.........or maybe they do already which could be why the original seller doesn't sell them anymore.
don't know if it helps but there is a company on ebay that sells blankets all sizes that will re-wire the blanket to suit your own press even cheap Chinese ones to the more expensive one.....hope that helps in some way
Can you make one with a siliicon sheet wrap it around the mug and add a couple of mins extra to time.
Just a thought. I do it with water bottles etc.
Iam going to delete every single post you did today as this is getting ridicules
i think those posts are old and dead for long long time.
