Fold ayay heat press
Re: Fold ayay heat press
...For a more standard press, we love the PressMech A3 press ... (this after using Jarin, Adkins, and Insta, along with a selection of expensive and cheap Chinese models.)
johnfrancis
Justin which of these two heat presses would you recommend Hotronic Fusion or Beta Major...........thanks
johnfrancis
If you had the choice between Hotronic Fusion press or Beta Major which one would you choose.........
Beta Major for me but that is probably because I have had Adkins in the past and have never used a Hotronic. If it was between those two I think for me it would probably be price. However, I think there are more Adkins resellers than Hotronic. This is a very very slight advantage should anything ever go wrong as you have more options for sourcing parts etc. As mentioned this is a very small advantage as they are both very good machines.
johnfrancis
Thanks Sociagiraffe I'm going to Focus this weekend so I can talk to express. The work I have in mind for the press is photographs onto Chromaluxe nothing else, so would-these type of presses be over the top......
Hi Johnfrancis
Having used both really expensive ones and cheap ones there really is not a huge difference in the actual pressing. It is probably more important to figure out if you need a swing away or a clam shell. People on here that press Chomaluxe will be able to advise you on that as I have never used it.
The real difference is in the build quality.
Think of it like purchasing a car. You can purchase a Skoda or a Rolls Royce. Both will do the same thing in that they will get you from A to B. In theory the Rolls will last considerably longer than the Skoda but will cost you a lot more.
Adkins and co are designed to be absolutely hammered all day everyday. If this is a new venture I personally would recommend a cheaper press from a reputable supplier. If the business takes off then you can look into getting a better heat press. At least then your will also have a back up press should anything go wrong. You will aos have much more personal experience as to what your exact requirements are.
- Has thanked: 11 times
- Been thanked: 9 times
I use this Adkins model but mine is a slightly older version which I personally prefer. Adkins are excellent but if I was buying new right now I'd probably give the Hotronix a shot.You don't need to be spending this much but if you have the budget it'll serve you well for many years.
johnfrancis
Hi Justin had a word with Target They want £2900 plus vat if I was in the states they sell for £1280...........Justin;66636 wrote:Also take a look at the hotronix machines on target transfers site
- mrs maggot
john, dont forget even in the states depending on which state you are in you have tax to pay of up to 28% on that price,
