pressiton LIVE NOW
Re: pressiton LIVE NOW
like john said... it may be your browser. or try to update flash player.
That looks brilliant! Wish I could use it
All I need is a website ...................... would buy without hesitation.
you can contact Chris and he will sort you out with web site
still the same in chrome john
does the image wrap right around mug ?
or can it be put on both side ? - like you would in real life ?
i cant see it properly to evaluate it - DAM CONNECTION
[ATTACH=CONFIG]1560[/ATTACH]
see what i mean ?
must be the mobile connection
see what i mean ?
- vB_ID:1560
- Untitled.jpg (82.55 KiB) Viewed 260 times
no. only on website as it can be linked only from directory.
and your photos doeas look like image dond cover all mug. also mug is much lower then it should be. have you got new flash installed?
same in chrome and IE- flash up to date paul. Must be the connection.
Only got till monday then full b/b back on ....been a hard week or 2 try to do things online - very, very frustrating indeed !
i think you need to see it on different connection to confirm it :/
