is coralgraph sublimation paper any good
scottmurray89
Re: is coralgraph sublimation paper any good
Post by scottmurray89 »
hi there, is coralgraph sublimation paper any good? is there much difference between that and the stuff from bms?
thank you
Simon
Post by Simon »
Ive had bad experience with it. Never had a problem with trupix or xpress :-)
Personally I only use Xpres, don't rate the CG paper.
JSR
Post by JSR »
I have some Coralgraph paper and it is tolerable but you've got to ask yourself why you want to use it. If printing 3 mugs from an A4 sheet, the price difference between Coralgraph paper and TruPix is 3p per mug. You could add that 3p to the end-price of your mug and use decent paper.
However, if you feel that that 3p is more important to you than the print quality of your mug, I wouldn't want to be your customer. :wink:
Xpres paper is better than Coralgraph paper, but TruPix is better than that.
