Xpres Paper Sticking to Mugs
Stitch Up
Re: Xpres Paper Sticking to Mugs
Post by Stitch Up »
I'm sure I solveed this before!
When we print a mug using the Xpres transfer paper 3.5 mins @ 200 using light pressure, the paper sticks to the mug. I recall that the paper used to just fall away.
Any tips - been a while since we did mug printing!
John
Which mugs? Could be the coating on them. We recommend pressing at 180, your temp might be too high as well.
Stitch Up
Post by Stitch Up »
Thanks for the reply Martin.
The mugs are probably from TMT as we can't remember buying from elsewhere! We haven't used any in 6 months or so.
We'll reduce the heat and try again - will report back.
Is there an accurate way to test the actual heat of the presses?
Cheers
John
You can test temp on blanket with an ifra-red thermometer. About £20 to buy from places like Maplin.
Andrew
Post by Andrew »
Certainly sounds like to much heat to me as well. Melting the coating a touch which then allows the fibres of the paper to attach. 200c shouldn't melt the coating if the temp is correct. I have a starting point of 195c for 2.5 mins which usually is spot on for most prints and that is on a few different press makes.
frizbee
Post by frizbee »
Xpress paper is basically espon matt which should be fine at 200 as we use it all the time on hard stuff at that temp.
TMT unfortunately are low quality mugs, and if using one of their Black presses for mugs they recommend, idle 150 print 190 and time 15 seconds.
This may not solve you issue but it is the TMT way of doing it.
Been thanked: 12 times
frizbee wrote:Xpress paper is basically espon matt
Is that right David? Use Xpres paper for years and it was very good, different feel and weight to Epson matt though.
Andrew
Post by Andrew »
I find Xpres gives a slightly better print than the Epson. Decent paper for most substrates.
