Oven Success I want to hear YES!
Re: Oven Success I want to hear YES!
Hi Amanda
I am using presses at the moment, but have a customer looking at various things, none of which will fit in a press. If I end up using an oven and wraps I might just as well do a deal for the full range of wraps in one go, then really make the oven work.
Janners.
Back on google now so the return key works. On Explorer the return key does nothing, but only on this site, most odd.
Janners.
Makes sense but sounds like a few pennies, you folk have too much money in Englad:biggrin:
swimwivsquid
I use a small oven bought from Argos I think. Use wraps and a thermometer to make sure the temp stays at 200. Takes a few minutes to stabilise but once its set it holds the temp fine. I tend to put the mugs in for 15minutes which seems to work for me. Main advantage is number of mugs that one can do and also wrap right around the mug.
Amanda you are talking to the person who orders until the postage changes, then takes the last item off. Yes I am so tight my order sheet is done in priority, and if I can't maximise the postage band, it can wait.
I think I actually hear my suppliers groan over the internet when I order.
Swimwivsquid - I was looking at one and thinking it was a neat sized unit.
Janners
Janners
Halogen oven with extention ring
