Templates for mugs
Re: Templates for mugs
When people are talking about templates do they mean the type from:- http://www.frames4photoshop.info/209-ph ... lates.html
Or is there a different type that is being talked about.
I have had a lot of requests for the parody on the Keep Calm theme, yes I know there is some fuss about the original 'Keep Calm Carry on' but the parody ones are totally copyright free, so use them quite a bit.
- mrs maggot
Hi james, this post will need moving to artwork perhaps ?? but yes when people talk about templates that is what they are referring to in general, Paul sells his on here.
Opps, sooo sorry, still new to this and not found the Artwork section yet.
James
James
- mrs maggot
thats ok its been moved, have a good read around the forum while you are here, if you join you can get access to some free templates that paul puts on the site from time to time, and they should be great to have a play around with
Um, can't afford PS yet, unless there is some cheaper program I can use?
James
James
Cs2 is free download
I saw a thread on that somewhere, but then when I went to the site I couldn't find it. Does someone have a link?
