Printing on bottom of mugs
viccar
Re: Printing on bottom of mugs
Post by viccar »
I have seen those as well,
i did wonder if they were vinyl (seen glasses with vinyl on) but it does say they are printed.
John G;64131 wrote:Just tried on a swing away flat bed heat press - there doesn't seem to be any sublimation coating whatsoever on the bottom of BMS mugs as there wasn't even a faint print left after 190/190 with 2 sheets of silicon. Maybe Martin can confirm whether there is a coating on the bottom of the mugs or not.
Cheers John
There may be over spray but they aren't specifically coated. There were a couple of members here that did the solvent stickers from memory, but this may help:
http://www.dyesubforum.co.uk/vbforum/sh ... -mug-bases
RogerC
Post by RogerC »
bms;64156 wrote:There may be over spray but they aren't specifically coated. There were a couple of members here that did the solvent stickers from memory,
I can offer eco solvent ink printed decals/stickers (call them what you will) on clear or white vinyl to forum members if it helps. Full colour printed on a Versacamm.
viccar
Post by viccar »
Do you mean these mugs?
Contents may offend
http://www.ebay.co.uk/itm/Surprise-IM-A ... 3a7de39e1e
gorgall2
Post by gorgall2 »
I think those could be done with a pad printer.
James990
Post by James990 »
Yep, these (http://www.ebay.co.uk/itm/Surprise-I...item3a7de39e1e) are the ones, so how are they doing it then?
mrs maggot
Post by mrs maggot »
As Gorgall says probably with a pad printer
James990
Post by James990 »
Sorry for my ignorance, but what is a pad printer, please? Where does one get one from, and how much are they?
mrs maggot
James, just google pad printing, and you will find thousands of entries, close to the top will be you tube videos explaining the process, and further down equipment sellers, but its not something cheap as such - but google and you will find
