Ricoh SG 3110DN How do you set it to Mirror the image?
chris_hosk
Re: Ricoh SG 3110DN How do you set it to Mirror the image?
Post by chris_hosk »
Questions in the title lol how do i set it to mirror the image?
using Windows 7.
Chris :)
SciArtImages
Post by SciArtImages »
If the Powerdriver is the same as the older model then there is a tickbox in the pop-up that comes up to set printing options (substrate, paper, saturation etc).
Neil.
Science meets Art - microscope photographs revealing the beauty of the world around us.
http://www.sciartimages.co.uk
http://www.facebook.com/SciArtImages
Simon
Post by Simon »
SciArtImages;63764 wrote:If the Powerdriver is the same as the older model then there is a tickbox in the pop-up that comes up to set printing options (substrate, paper, saturation etc).
Neil.
I use powerdriver in win7 and I can confirm exactly that ^ :)
chris_hosk
how do i get to it i cant seem to find the setting?
Simon
Post by Simon »
I use CS4, so it may be different for you, but when you select the printer, ie powerdriver, there is a preferences option; choose that and you will see this:
HTH
chris_hosk
brilliant thanks i will check this when im back in the office tomoz i appreciate your help everyone
mrs maggot
Post by mrs maggot »
i leave mine as it is, and before i save my work into a file i mirror it, so now i know if i can understand it - i dont print it lol
JHP
Post by JHP »
I spoke to Sawgrass about this last week and the Ricoh SG 3110 printer software will not reverse the image, you will need to do it in Photoshop! Or which ever software you use.
A bit pathetic i think as i have never had a printer that does not have the mirror image facility.
JMugs
Has thanked: 9 times
Post by JMugs »
I use one, and yes it does. Little tick box says mirror image. Look at screen shot above.
Janners.
