printer i can use for printable flex??
Re: printer i can use for printable flex??
hi
i have bought the epson SX535W for printing onto vinyl flex, I got this printer as was told i needed to use a printer which used durabrite ink, which this one does
BUT as u can see from the pic it is doing exactly the same as my other printers, the ink is just sitting on top[ of the flex??
What am i doing wrong??
- vB_ID:1476
- flag prnt (2).jpg (98.6 KiB) Viewed 479 times
can ou post link to this flex???
i am printing on the side with the flex on??
heres a link to the product im using, it says use durabrite inks which is why i purchased this specific printer, and now im still tearing my hair out
http://www.printerowners.co.uk/garment- ... e-flex.htm
thanks
thanks
hmmm... mabe you got wrong settings?? do you print on best photo??
ive tried all different settingsPaul;63726 wrote:hmmm... mabe you got wrong settings?? do you print on best photo??
Give martin a shout. He should e able to help you.
Martin's away on holiday and won't be back until next week apparently!!
Then iam sure there is scotty ready to answer all phone calls
could be totally wrong and miles away as i have never used this,so sorry if it sound stupid but it says "Printable flex comes in A4 sheets and in 500mm widths sold in linear metres. It comes complete with it own backing sheet so you can cut the top layer and peal off for application to garments."
Are you printing onto the backing sheet?
