cheers for any help
rob
The best way of getting the information is call BMS. They can tell you excatly what the potential costs per sheet are although the Sawgrass link above does give a pretty close estimation. You will find the 3110 works out more expensive per sheet than the 7700 because it only uses the smaller cartridges whereas the 7700 uses 60ml carts as opposed to 29ml. The carts for the 7700 are not double the price of the 3110 carts ergo cheaper per sheet although you are looking at a lot more for the 7700 printer (although this does give greater flexibility if you need to expand your product line) and is expensive if you have no need of an A3 printer.The Housewives Favourite;62610 wrote:Thanks Roger, was looking on their site last night so will probably end up buying from them, but was a bit confused about the size of in cartridge, i know its a gel ink with higher viscosity etc (i watched the video), but was wondering about the return as if i buy a dinky cartridge for my inkjet and do say 40 t shirts with heavy coverage then its gone, so was trying to work out cost per sheet based on medium coverage, also how come the ricoh doesnt clog as much? just curious thats all
Users browsing this forum: Amazon [Bot] and 0 guests
