Ricoh GXe3300n - Set of inks For Sale
chris_hosk
Re: Ricoh GXe3300n - Set of inks For Sale
Hi,
I purchased a GXe3300n but when it arrived it wouldnt switch on :S
so i have for sale 4 ink cartridges new havent printed a thing i put them in the printer but when the printer wouldnt turn on i removed them and put them back in the box these are real SubliJet i purchased 2 recently from Coralgraph and the other 2 came with the printer and unused and are also Sublijet
Will take £140 for all 4 shipped
chris_hosk
chris_hosk
Now on eBay 1 day auction 99p start http://www.ebay.co.uk/itm/Ricoh-GXe3300 ... 43b7687d10
Hi Chris - why not contact your local Sawgrass Dealer to buy a new printer? This way you would get a proper set-up and not have to "almost" give away a set of carts.
chris_hosk
i have and will be buying a new ricoh printer but from what i understand these inks are not compatible im getting Ricoh SG 3110DN
Dont realy understand why a 1 day auction, dosn't give much time for people to see the listing.
Also i would have put them as used, as the seal has been broken, just to cover yourself.
Chris - why buy an R-3110 when the R-3300 is a newer generation & only a very little more expensive? check out the Sawgrass website to compare the 2 printers
Think you may have this the wrong way around Barbara. The SG3110 is the newer machine. The GXe3300 has been discontinued for some time.Sawgrass;62269 wrote:Chris - why buy an R-3110 when the R-3300 is a newer generation & only a very little more expensive? check out the Sawgrass website to compare the 2 printers
bms;62284 wrote:Think you may have this the wrong way around Barbara. The SG3110 is the newer machine. The GXe3300 has been discontinued for some time.
