paper or silicon ?
steve 1
Re: paper or silicon ?
Post by steve 1 »
hi guys i hope to get my mug press tomorow i have seen on you tube about wrapping the mug in a peice of white paper to stop ink bleeding through to the blanket. i have just been reading on another post about people using silicon sheet around the mug is this for the same reason or another reason
thanks steve
i never used anything to protect my blanket and never had any bleed. but if i use one it will be teflon sheet.
silicon has bit different purpose. its for smaller mugs that are bit loose in the press or has uneven surface.
steve 1
Post by steve 1 »
thanks for the explanation paul re silicon i may get a teflon sheet just as a precation if thats what is reccomended
you can also use cheap copier paper cut in to the strips.
steve 1
Post by steve 1 »
Thanks paul why cut into strips ? i would have just wrapped around mug
accdave
Post by accdave »
steve 1;62061 wrote:Thanks paul why cut into strips ? i would have just wrapped around mug
I don't think he literally meant strips, he means cut down to mug size, or slightly bigger :wink:
steve 1
Post by steve 1 »
thanks dave me being a bit of a thicko ne thinks
Renniwano
Post by Renniwano »
I use silicone paper cut to just larger than the mugs..
logobear
Post by logobear »
we found that provided you cover the whole mug with sub paper, then we never have a bleed problem, the odd time we have been tight and trimmed the paper too tight to the image so some mug is not covered, then there can be a danger of bleed through from the blanket.
BUT - given that the paper cost is low compared to the ink (or mug cost) we only print 3 mugs per A4 - and make sure we have enough sub paper to fully cover each of the 3 mugs, and then never get any bleed through.
Easy !
Use a decent paper like TRUPIX and then you should never get any bleed through.
Users browsing this forum: Amazon [Bot] and 5 guests
