Help - Problem with printing on sublimation film!
olleolle
Re: Help - Problem with printing on sublimation film!
Post by olleolle »
Hi,
First thanks for a fantastic forum and sorry for my bad english.
I have recently invested in a printer Epson WP-4015 but I have a big problem when I print with sublimation film http://sublideck.com/sublimation-3dfilm.html
The printer feeds a littlebit and then stops and says jams. It works fine if I try with plain paper. I guess it's because sublimation film is a bit transparent.
But this is the printer vendor recommend so it should work. Guess it's something I missed?
Grateful for advice
Thanks.
Ian M
Post by Ian M »
Hi Thomas, Try a photo paper setting to see if that helps. It might be a good idea to speak to Sublideck to see what they say about the problem.
olleolle
Post by olleolle »
I have try with all the paper settings, the only way that works is with "Plain paper" but then its only only with low print quality. I also tried to reach Sublideck, but i guess they closed for the holidays :(
olleolle;61825 wrote:Hi,
Grateful for advice
Thanks.
Presumably you're using PowerDriver for the Sublijet-IQ inks in the Epson printer? If so, then does it not work with the default option in the PowerDriver software?
We're experimenting with similar paper, but there is a transparent as well as gold coated film. The gold coated film removes the transparency issue so it is 'seen' as paper by the printer.
olleolle
Post by olleolle »
Im use the default Epson driver that comes with the printer. Could that be a problem ? Maybee there is another ?
olleolle;61844 wrote:Im use the default Epson driver that comes with the printer. Could that be a problem ? Maybee there is another ?
Here is the support section for your printer. Click through to PowerDriver...
http://www.sawgrasseurope.com/technical ... ments/4015
