Small Heat Press
Online
Has thanked: 13 times
Been thanked: 12 times
Re: Small Heat Press
Looking for a small heat press, probably 9" x 12, 12" x 12" etc. to run alongside my larger press.
Need to be able to press the acrylic blocks etc. so 20mm gap with lock down is essential.
If you have anything suitable and want to sell please let me know :-)
Si Da Signmaker
Post by Si Da Signmaker »
Hi Justin,
After much searching around myself, as you might remember from a previous thread, http://www.dyesubforum.co.uk/vbforum/sh ... en-plaques with the help of Martin from BMS I am just about to purchase this one http://www.printerowners.co.uk/hardware ... -press.htm . To quote Martin "It would press material about 6" thick as the press opens along way!". Not sure about the lock down, is there a reason that`s essential?
Regards
Si
WorthDoingRight
Post by WorthDoingRight »
Online
Needs to lock down to get constant pressure across the blank over a 7 or 9 minute press time.
WDR, this is one of the presses I want but they're all through the Chinese distributors and I'd sooner avoid if possible, may have to bite the bullet though.
ADP
Post by ADP »
What about one like this? http://www.ebay.co.uk/itm/PixMax-38x38c ... 3ccd503595 Have you heard of this company before as i quite like the look of it in red :)
Online
Looks OK, it bigger than I need bit worth a look thanks :-)
ADP
Post by ADP »
Did you manager to find a press what you wanted in the end?
Online
Yes thanks (and thanks for the reminder to update the thread!) Bought one from Coralgraph, just a Chinese one but it's perfect! ;-)
ADP
Post by ADP »
Thats good then, just thought i would see if you did get one :)
