NEW HEAT PRESSES
Re: NEW HEAT PRESSES
HI ALL,I JUST THOUGHT ID LET YOU KNOW I ANYONE'S LOOKIN FOR A NEW VINYL CUTTER OR HEAT PRESS (SWING AWAY OR FLAT) CHECK THIS GUY OUT ON EBAY USER NAME goldenplotter ,I HAVE JUST BOUGHT A NEW 50" VINYL CUTTER WITH LASER POINTER PLUS STAND & BASKET,FROM HIM & A NEW HEAT PRESS HIS PRICES ARE VERY GOOD & THE PRODUCT'S HE SELL'S ARE BRILLIANT.HE ALSO DOES SUBLIMATION INKS & REFIL SETS IF YOU GIVE HIM A RING,HE IS ONLY IN MANCHESTER & YOU CAN COLLECT FROM HIM.
BYE FOR NOW.
BYE FOR NOW.
What is the cutter and heat press like now you have had chance to try them out? which plotter/cutter did you get? which heat press did you get?
thanks lisa
thanks lisa
Call me sceptical, but I thought I remembered reading a post exactly the same as this before
I think this may be what you guys read before
[url="http://www.dyesubforum.co.uk/forum/view ... tter#p3446]viewtopic.php?f=54&t=386&p=3446&hilit=goldenplotter#p3446[/url]
Seems more like a covert advert rather than a message - exactly the same text was put on a couple of threads in January (thanks KAZ).
No probs Martin
And the stories I could rell about the seller mentioned in the OP would make your toes curl
Maybe you should tell us, it might save somebody else using them and having problems.Kaz wrote:No probs Martin
I must admit I have looked at thier stuff on e-bay and wouldn't deal with them because their presentation doesn't come across as a proffesional outfit.
