Vinyl on polyester fleece
quasar
Re: Vinyl on polyester fleece
Post by quasar »
Trying to put hot flex vinyl on polyester fleece. Has anyone done this before? Vinyl does not look as good as on cotton tops I've done before. Looks all crinkly, as if it will peel of. Any suggestions.
Earl Smith
Post by Earl Smith »
Suggestion....Dont do it. It will peel off. Micro fleece might work but again , there are problems. Not enough contact area for the glue.
Only real solution is embroidery.
quasar;59660 wrote:Trying to put hot flex vinyl on polyester fleece. Has anyone done this before? Vinyl does not look as good as on cotton tops I've done before. Looks all crinkly, as if it will peel of. Any suggestions.
I've pressed a lot of fleeces with flock (we have some workwear fleeces ourselves) and they've been washed and worn a lot without any problems. Have also pressed flock on to fleeces for lifeguarding and again no problems. I personally wouldn't go down the route of flex though on fleece.
purpledragon
Post by purpledragon »
bms;59708 wrote:I've pressed a lot of fleeces with flock (we have some workwear fleeces ourselves) and they've been washed and worn a lot without any problems. Have also pressed flock on to fleeces for lifeguarding and again no problems. I personally wouldn't go down the route of flex though on fleece.
ditto................
crystaluk
Post by crystaluk »
Which flock is this?
bigj2552
Post by bigj2552 »
i,ll second what martin said. i done flock onto fleece with excellent results. both wash n wear and nothing coming off.
never tryed flex on fleece tbh
quasar
Post by quasar »
I have used flock before, but not on polyester. So will try that. Thankyou.
Earl Smith
Which fleece are you guys using? It doesnt work with the ones I use. I would like to know as Im often asked.
purpledragon
bigj2552;59721 wrote:i,ll second what martin said. i done flock onto fleece with excellent results. both wash n wear and nothing coming off.
you cant second it i already dittoed it which is like a second it you can third it or ditto my ditto or second my ditto or just agree with my ditto or conirm the ditto or third and confirm a ditto but its definatly my ditto ok i hope thats cleared that up
quasar
Post by quasar »
My fleeces come from Qtag
