Mug Ovens
Re: Mug Ovens
Hi, has anybody used or have a mug oven? Wanting feedback and thoughts of what you think of them and do they work better than mug presess?
Thinking of maybe buying one!
Re: Mug Ovens
had one and didn't like it.
+ 4 mugs at once
+ print closer to the nadle
+ cheap to replace if broken
- longer cooking time regardless if one mug or four
- hot as hell when taking them out and cooling longer
- expensive wraps
probably is only me but i found mug press working better for me
+ 4 mugs at once
- expensive wraps
Earl Smith
Re: Mug Ovens
Ditto for me, didnt like it. I got 5 in mine at once. You also need a duplicate set of wraps ´cause you need them fo the next set going in.
- WorthDoingRight
Re: Mug Ovens
If you are going to be buying an oven and 4 wraps then you have enough money to buy a mug press instead. I think that if you just wanted to make the odd mug and already had a suitable oven then buying a single or a couple of mug wraps could be a cheaper way to go. Obviously if you could get a big enough oven and loads of mug wraps then it might be quicker than a mug press on larger orders. I only have wraps for odd items such as cat and dog bowls where you do not really have any other choice.
Re: Mug Ovens
I use an oven.. admittedly takes longer but I do occasionally do cat/dog bowls lol
- SciArtImages
Re: Mug Ovens
In use an oven - I prefer to print as close to the handle as possible, and I print in batches so never have a problem filling the oven. It does take longer, but you can go off and do other things while it does its stuff. One piece of advice - get a good pair of heat resistant gloves!
Neil.
Neil.
Science meets Art - microscope photographs revealing the beauty of the world around us.
http://www.sciartimages.co.uk
http://www.facebook.com/SciArtImages
Re: Mug Ovens
There was a person on here, a lady I think, who used a JML Oven but didn't use wraps at all, just tape.
Is that truly possible?
- Has thanked: 11 times
- Been thanked: 9 times
Re: Mug Ovens
Used small ovens in the past, JML etc. not that keen. Running 2 or 3 separate mug presses a lot easier!
Re: Mug Ovens
I suspect Goldrapt it is possible but then I think you would use a lot of tape.
Personally I do not use ovens as they take too long when you are doing a run of 500. However this thread got me thinking about purchasing one and seeing if printing on the handle would be possible. I think in theory yes and it would be nice if someone with an oven could give it a go.
Re: Mug Ovens
I use one and have a mug press, I found the mug oven good, have used one for over two years, happy with the way it performed, just had to be careful of burnt fingers. I use when I have a order that needs consistently to be the same in colour. Heats my kitchen lovely, I cannot fault it.
