Hi all,
I'm looking for some dye sub aluminum sheet, but all I can find is 0.5 thick in various sizes. Ideally I'm looking for 1-3mm thick with a minimum size of 30cm x 40cm.
Surely there must be a supplier somewhere?
Please help
Sublimation Aluminum Sheet?
confidential
Re: Sublimation Aluminum Sheet?
There used to be some 0.7mm thick but this was never that popular. Not come across material that thick for standard sublimation use, but know where you can get steel sublimated in larger sizes. I can pm you the contact details of the company that does this if you're interested.
confidential
Thanks Martin,
Steel would be just as good as I guess, please pm me the details.
John
John
TransferGraeme
Dependent on the quantity you need we may be able to supply this - but it is very expensive and very heavy to move around!
We make our own signs and spray them white, the cover in sublimate laquer.
How many do you want and realitically what is your expected buy price and i'll see what I can work out.
They don't work out that expensive, mainly depends on the size of run.
confidential
Yes thought about going down that route, but don't really want all the hassle & mess.frizbee wrote:We make our own signs and spray them white, the cover in sublimate laquer.
Lets say 100 sheets of 30cm x 40cm x 1mm, would be the monthly order on average. Price wise? shock or amaze me
