Advice on faint transfers please
Craig
Re: Advice on faint transfers please
Post by Craig »
Glad you got sorted Mummywebb
mummywebb
Post by mummywebb »
Can't remember where I got the 50secs from but now I do them at 200c and 90secs and works perfectly! I got my ICC profile even though I was happy with the colours but it made the colours ways too dark so I won't be doing that again!
mummywebb
Post by mummywebb »
Craig;58828 wrote:Glad you got sorted Mummywebb
Thanks! :smile:
If you have a problem with a custom ICC making your colours too dark, then you should ask whoever made it to tweak it for you.
Out o experience i know that some blanks may turn out darker. But colors will be still great. Is douwn to shinest of the surface. Easyto tweek ;-)
JackB
Post by JackB »
With Xpres paper it is hard to tell which is the whiter side in some lighting situations, if you lick your thumb and forefinger and then pick up the paper at the corner, the stickier side is the printing side.
Jack/
mummywebb
Post by mummywebb »
Yes apparently the seller has a new profile coming so I may see how that turns out instead. I could get quite addicted to this though!
mummywebb
Post by mummywebb »
Paul;58896 wrote:Out o experience i know that some blanks may turn out darker. But colors will be still great. Is douwn to shinest of the surface. Easyto tweek ;-)
Thanks Paul I may need to experiment a bit!
JackB;58900 wrote:With Xpres paper it is hard to tell which is the whiter side in some lighting situations, if you lick your thumb and forefinger and then pick up the paper at the corner, the stickier side is the printing side.
Jack/
Thanks Jack it is hard to tell but I like that tip!
