also i am going to be working on the S22 but would love to upgrade to a Ricoh once settled so if anyone is selling a decent printer drop me a PM
Sublimation Prints
chris_hosk
Re: Sublimation Prints
Hi, my ink is about 2 weeks away and i am desperate to play with the mug press and have 36 mugs to mess about with (ok maybe i will only use 5-10 to play with) is their a place i can order a few pre prints so i can learn to use the mug press i only want 4-5 to play with
The results you get with sublimation prints will vary considerably based on (1) ink used, (2) quality of mug coating, (3) quality of mug press and (4) colour profile. If you get some prints from someone on the DSF using supported inks with colour profile then you may be surprised at the difference you get once you start experimenting with your S22.
I hope you manage to get this up and running (for your sake, I really do) but experience and phone calls tells me you may be seeking an upgrade after you've spent your money on a paperweight and we do have many phone calls that start off just as you are doing...
- Has thanked: 11 times
- Been thanked: 9 times
From your post above it looks like you're importing your own inks. We can't discuss or support any third party inks on the forum due to the Sawgrass small printer patent that applies. It's quite possible you'll get perfectly good results with your set-up but you'd immediately need a profile creating to match your printer/inks/paper.
S22 is one of the most basic printers. You're obviously already thinking about the Ricoh, personally I'd have saved my money towards this as you'd be set-up 'officially supported' straight away with invaluable supplier support and also ongoing forum support. For what you will have invested I'd advice you still go the Ricoh route. I doubt you'll find anyone willing to part with a Ricoh, hens teeth springs to mind...they tend to work out of the box and (on the whole) keep working....hence you make your money quicker!
Best of luck whichever route you take but as you'll read time and time again on this forum, buy cheap buy twice
chris_hosk
Thanks for the replies, i think next month i will buy the Ricoh tbh i wasnt aware what was best and chose purely on a "how to" video using the S22 i didnt even know this forum exsisted and had already ordered the bits before i found you all lol
What would you suggest as a good set up to start me off? worse case i can use the Epson as a backup?
- WorthDoingRight
Printerwise the Ricoh SG3110DN bought from a Sawgrass authorised dealer complete with Sawgrass Sublimation cartridges is a solid starting point to build upon.
chris_hosk
thanks are these guys autherised http://www.ebay.co.uk/itm/Ricoh-SG-3110 ... 20caee9693
regarding ink do sawgrass or someone have a website so i can check prices as i want to budget for this.
If wanting to use Sawgrass inks, then you are best to buy the inks and printer from a recognised/authorised Sawgrass dealer as a package.
chris_hosk
- WorthDoingRight
Well a good first place to look is on the BMS website http://www.printerowners.co.uk or the Listawood website http://www.listawoodtradesupplies.com
Full list of dealers available from here http://www.sawgrasseurope.com/
Printerland just sell the printer. To get full warranty backup you'll need to buy the printer and inks from an authorised distributor - the printer isn't the expensive part, the inks are and your buy price for the printer and ink will be about 3x the cost advertised on the link.chris_hosk;58812 wrote:thanks are these guys autherised http://www.ebay.co.uk/itm/Ricoh-SG-3110 ... 20caee9693
