Coasters
TransferGraeme
Re: Coasters
The European distributor we use decided to stop bringing the light ones over - I believe he has seen the error of this and the light ones will be available again soon!
Re: Coasters
We get a good price from xpres, certainly less than list but we have to buy a lot (over 20 Boxes)
I will email Martin @ BMS and see what his deal is like as I need at leat 400 this week and never realised he did unisub.
As much as I don't like the company Novachrome, have theirs made from Unisub sheet so can do a deal but we don't buy from them.
David
David
Re: Coasters
Depends what finish you want on the coasters. The UniSub coasters are expensive as they are bought from a European distributors and with the £ v € exchange rate then "deals" on UniSub are hard to come by. The UniSub board has a sprayed finish so you get a very clean smooth effect, but with the brand and the finish there is a price to pay.Anyone ever noticed cheap coasters on their travels?
Do you need the coasters to be made of wood or would the fabric type (like mousemats) or the metal types do?
Re: Coasters
It's the 9cm square hardboard unisub I currently use and need to keep continuity running through. I have used non-unisub in the past which was virtually identical but was getting a decent price from Xpres. My main problem is that now and then I get asked for larger quantities so I need to be able to drop my pricing when needed. I get about 10/20 boxes each time as standard depending what I have on but never really get the price lower when looking for much bigger quantities.
TransferGraeme
Re: Coasters
9 cm square coasters now in stock at an introductory price of 43 p each (though always worth giving me a call if you want a big quantity!!)
