mug press having a hissy fit now !
bigj2552
Re: mug press having a hissy fit now !
Post by bigj2552 »
went to try out some new designs tonight.
usual temps and times my mug press is always set at..mug in, press start---
paper going brown at top - black coming out diff shade, reds going pinky...WTH :rolleyes:
i aint touched nothing since the last mug last week....
next mug - same settings -
faded at the bottom corners......some strange shit going on here.....the mug gremlins have been in over the week :rolleyes:
ONLY THING I DID DIFFERENT THAN NORMAL, WAS MAYBE SLIGHTLY MORE PRESSURE.
surely that wouldn't cause this ? :confused:
oh...BMS MUG PRESS AND MUGS before anyone asks :wink:
time- 180sec
temp 180c
medium to high pressure
mug in before for preheat.......
JMugs
Has thanked: 9 times
Post by JMugs »
Same equipment, same supplier, ultra white mugs.
170 degrees, 140 seconds.
Any hotter and / or longer and I get browns from black and reds go off, sort of vaguely dirty faded.
Not saying It's the answer, just my figures.
Janners.
Craig
Post by Craig »
I do mine 180 degrees for 140 seconds and light pressure just enough so mug dont turn when clamped
bigj2552
Post by bigj2552 »
JMugs;57805 wrote:Same equipment, same supplier, ultra white mugs.
Janners.
thats whats happening now.....blacks are browny, red are pinky....and paper is seriously burnt at the top.
but - i been using these setting since i got it - 180c- for 180secs and has been working perfect :confused:
bigj2552;57807 wrote:thats whats happening now.....blacks are browny, red are pinky....and paper is seriously burnt at the top.
Settings should be: idle temp 110 degrees, mug in and press start button, operating temp 170 degrees, time 140 seconds. Blacks going brown is too high a temp for too long (temp settings are for Ricoh printer and SubliJetR inks, Artainium inks would require 180 degrees).
bigj2552
Post by bigj2552 »
bms;57811 wrote:Settings should be: idle temp 110 degrees, mug in and press start button, operating temp 170 degrees, time 140 seconds. Blacks going brown is too high a temp for too long (temp settings are for Ricoh printer and SubliJetR inks, Artainium inks would require 180 degrees).
i dont use idle martin - set for 170 for idle and printing...i just put blank mug in while heating, then whip it out 2 secs from 170....insert printable mug and press start
lowered the temp to 170c - time to 175sec.....yes.
back to good again....
really strange i had been using 180 and 180 since day one......could be something to do with inks settling ?
[ATTACH=CONFIG]1270[/ATTACH][ATTACH=CONFIG]1271[/ATTACH]
excuse the camera flash !!
vB_ID:1271
vB_ID:1271
vB_ID:1270
vB_ID:1270
JMugs
Post by JMugs »
Sorted!
Janners.
Craig
Post by Craig »
glad you got it sorted Johnny
bigj2552
Post by bigj2552 »
me to...cheers guys - just need to keep an eye on temps more often me thinks.......coffee time
