Mug Image Position
Fordy
Re: Mug Image Position
Post by Fordy »
Hi,
I've been given an image which is not wide enough to wrap around a mug properly, but it is too big to double the picture up so it appears on both sides.
So I was wondering would you put the image in the center of the mug (parrallel to the handle) or over to one of the sides?
Usually I would ask the customer, but if the customer had given you no particular preference then what would you do?
Obviously theres no definitive answer to this and I suppose you could get away with either I just wondered if there was a norm when it came to this kind of thing.
Heres some pictures of the image and positioning to help explain better
Online
Has thanked: 13 times
Been thanked: 12 times
I'd do this front and back, why don't you think it would fit?
Fordy
Post by Fordy »
I use a 539x255px canvas to put the images on (anything wider and I get faded edges) so to double the image up on this size canvas I'd have to lower the height too much.
Russ
Post by Russ »
Image centralised opp the handle, and some text either side of the image to fill the space up to the handle?
Online
10 or 11oz mug? I use 10oz and print 200mm x 85mm
Personally I would center it. But if I could, I would clarify with the customer before printing.
purpledragon
Post by purpledragon »
i must be in a good mood
[ATTACH=CONFIG]1258[/ATTACH]
vB_ID:1258
vB_ID:1258
mug suggestion.jpg (83.81 KiB) Viewed 887 times
jennywren
Post by jennywren »
Russ;57098 wrote:Image centralised opp the handle, and some text either side of the image to fill the space up to the handle?
I do the same, and it looks good
Fordy
Post by Fordy »
Justin;57099 wrote:10 or 11oz mug? I use 10oz and print 200mm x 85mm
Sorry I use 10oz mugs.
Thanks for the advice, it seems going down the center is the general consensus. Adding text would be a good idea but I'm not sure if they want text. I'll confirm it with the customer before printing anyway.
Online
Sorry, I thought we were assuming customer gave no instructions, we could come up with 100 different ideas if you want! :-)
