Andrew, slightly off topic but do you use an oven for printing or something else?
I could see how masking tape would work in an oven envrionment, but not so sure if the tape is touching the heated silicon wrap as in a more convential mug heat press.
Alternative tape for mug press
Re: Alternative tape for mug press
That would be both presses and ovens Simon. Many masking tapes do leave a sticky residue but there are a couple which are fine to use.
