help required please
Re: help required please
Like said earlier It is a minor adjustment in your image,spacing from the bottom and top edge of the cup and applying a little more pressure on the cup you should be alright
I'm in agreement with a few comments here. I would always allow a 5-6mm gap top and bottom. I think it looks much neater as well.
Looks like a mat pressure thing to me. I had a similar problem to this and upped the pressure. Just make sure the paper is nicely squeezed around the top and bottom of the mug and if you're lucky (like I was) the image will be fine.
As a few of the other have stated this is possible the best route to go down, better a small gap then another unsaleable mug that your stuck with. I have a good mug press and a cheap one, both work well with the 5mm gap. I do a 5mm gap at the top to safe as I already have more than enough mugs than I could possible drink out and also my friendsWorthDoingRight;56518 wrote:Any image that goes fully to the bottom of a mug has the potential for issues. The safest way to avoid these issues is to avoid trying to print right to the bottom and leave a 5mm gap. If you just have to have it right to the bottom then trying the tips posted before 'might' get you the result you require.
thanks for the replies everyone. I increased the pressure and its better thanks. still I little vague at the very bottom edge but that's due to shape of the mug.
Thanks very much for all your help
Purpledragon - do you mind me asking which mug press you use - i'm looking to upgrade as have a middling priced one at the moment. Thanks
Katya, BMS sell some very good mug presses & you can find them here http://www.printerowners.co.uk/hardware ... -press.htmzai2289;57140 wrote:Purpledragon - do you mind me asking which mug press you use - i'm looking to upgrade as have a middling priced one at the moment. Thanks
